LasseA wrote: ↑1 year ago
PTRACER wrote: ↑1 year ago
Even without the patch, you still have 6 other ways to damage your engine so drive carefully
How many ways are there overall?
Besides damage to the suspension when having an accident, these are the primary damage types listed in the physics editor:
Overrev damage
Oil Temp Damage
Water Temp Damage
Oil Pressure Damage
Fire Damage
Propagation Damage
Random Damage
I have never investigated any of these in depth, but this is how I guess it would work based on various things I've seen:
Overrevving, oil temps and water temps - Below the specified limits there is no damage. Above that, the amount of damage it does probably depends on how far over the limit you are. i.e. Your engine will fail sooner at 20C above peak oil temp than at 10C above.
Oil pressure - Max pressure in game is 79 PSI, so maybe this is damage from
low oil pressure. Which would explain why blow ups can happen when warming up on the grid.
Propagation damage - I never knew what it is, but the word "propagation" suggests that damage in one area can affect another. So perhaps this is an overall counter of some kind. Meaning all the damage you have done is combined into one figure. A combination of overrevving, overheating oil and water could cause a failure sooner than any one of those things could on their own.
Random damage - Again, no idea how it's calculated because I haven't looked. If this is a probability based system and damage physics are calculated once per second, then based on the parameter, it looks like there is a 100% chance of a random failure occurring within 20 hours of driving. Someone once said on SRMZ that physics are calculated 4 times a second, in which case a failure is guaranteed after 5 hours of driving. Or 50% chance after 2.5 hours. Might have implications in the 1937 mod, if they have 3-4 hour races.
Besides the strength of the suspension which can be specified per chassis, the values above are applied equally to all cars. So, when we talk about Hondas blowing up before Brabhams, it's only because they can overrev further and run at higher temps than the Brabham can.
