Star wrote: ↑2 years ago
Apparently Aston Martin are going to appeal the disqualification of Vettel's car and it will be heard on Monday. If they are right, he may get back his 2nd place after all and they can all swap the trophies around again
And the verdict is in......
Aston Martin fails in review bid of Vettel's Hungarian GP DSQ
Aston Martin initially believed that telemetry data from the car showed there to be 1.44 litres more fuel in the car than the 0.3-litres that the FIA initially was able to pump out. It reckoned that a fuel system failure in the car had contributed to the circumstances and meant that the fuel had not been pumped into the tank where the FIA could access it. The team launched both a right to review request with the stewards, and also has formally appealed against the decision.
At the FIA hearing on Monday, the FIA denied Aston Martin’s request to review the case because the latest indications from the team were that a mechanical problem potentially meant there was not one-litre of fuel left at all.
For the request to review to be accepted, Aston Martin needed to provide a ‘significant’ and ‘relevant’ new element that was discovered after the event and had been unavailable to the competitor at the time of the decision.
At the hearing, the team submitted analysis from more than 100 channels of fuel-system related data to show that there had been a fuel system failure in Vettel’s car.
This failure of fuel cell pressure meant the air pump in the fuel cell activated a maximum output which, by pumping air through the fuel cell, meant a significant amount of fuel was discharged from the car. It was this failure that meant only 0.3 litres of fuel could be extracted afterwards.
The FIA accepted that this evidence, which pointed to a malfunction of the fuel cell pressure relief value, was a new element.
After further investigations by Aston Martin, it emerged that the team believes that there was actually less than one-litre of fuel remaining in the car at the end of the race due to the fuel system problem. Therefore, the FIA felt that the new evidence was not relevant to the case.
The FIA Statement
An FIA statement said: “For the assessment of whether or not the one-litre requirement was broken, it does not make a difference why there was less than one litre.
“There may be a couple of explanations why at the end of a race the remaining amount is insufficient. In any case, it remains the sole responsibility of the Competitor to ensure that the car is in conformity with the regulations all times (Art. 3.2 FIA International Sporting Code) and it shall be no defence to claim that no performance advantage was obtained (Art 1.3.3 FIA International Sporting Code).
“In order to be able to affirm a “relevant” fact, Aston Martin would have had to present facts that actually more than one-litre of fuel was remaining. The explanation why this requirement could not be met is not relevant to the decision as to whether a breach of the regulations has occurred.”
