2024 R2: Long Beach
Including the Indy 500 and all junior series leading up to IndyCar
2024 R2: Long Beach
19-21 April.
News:
https://racer.com/2024/04/08/f2-champio ... ong-beach/
Reigning FIA Formula 2 champion Theo Pourchaire is on standby to drive the No. 6 Arrow McLaren Chevrolet across the April 19-21 race weekend in Long Beach if the injured David Malukas is unable to return.
2020 F2 runner-up Callum Ilott has been Arrow McLaren’s go-to solution for the No. 6, but he has a pre-existing commitment in Italy on the same weekend at the 6 Hours of Imola FIA World Endurance Championship event with the Herta Team Jota Porsche 963 Hypercar team.
Sorry Malukas, I hope you don't get better in time! Pourchaire would be great to see as a cameo.
#2
Post by John »
Yeah, I'd love to see Theo give it a go. Also hoping for Flying Meatball FRO to continue his hot streak he and MSR is on at the moment.
CEREAL IS A SOUP.
#3
IndyCar to continue experimenting with first practice format at Long Beach
The NTT IndyCar Series will try a different version of its 75-minute opening practice format in Long Beach this weekend to the one it trialed in St. Petersburg. The idea for the new format was pitched by its drivers during its preseason meetings.
At St. Petersburg, teams were given the first 20 minutes to run as they pleased with the 27 cars in attendance before pitting and after a five-minute pause, the remainder of the session split the field into alternating groups that ran for 10 minutes apiece.
At Long Beach, 45 of the first 75 minutes will be open for the 27 entries to use as desired before a five-minute break will separate the field into two groups, where a 13-car cluster will have the track to themselves for 10 minutes before they pit and the other 14 drivers will get 10 minutes of their own to close the day. Rookies are the only exception and will be permitted to run at all times.
“We’re definitely onto something,” A.J. Foyt Racing’s Santino Ferrucci told RACER. “I like the bigger opening session. The second part just needs to be adjusted from track to track, based on the length of the track. We’re doing four to five laps per run, and the laps take around a minute at Long Beach, so I wonder if shorter session towards the end that are more fitted to [qualifying simulations] would be better. Instead of 10 minutes, maybe six minutes so we get more of the split sessions. Or maybe eight minutes. But something shorter that’s more representative of the time we’d need to do a few quali sims.”
With 70 of the 75 minutes accounted for in the revised Friday format, the five leftover minutes have been reserved in the event of a stoppage, which history suggests tends to happen at least once per session.
https://racer.com/2024/04/15/indycar-to ... ong-beach/
ALSO.....
IndyCar’s second-generation aeroscreen will make its competition debut this weekend in Long Beach, one month ahead of schedule. Its second-generation upper frame — the “halo” — debuted in St. Petersburg.
Designed and manufactured in a partnership between Red Bull Advanced Technologies, Pankl, PPG and Dallara, the first version of the aeroscreen appeared as a mandatory driver safety device to start the 2020 IndyCar season and has prevented multiple cockpit intrusions — ranging from wheels and tires to suspension components and bodywork — since its introduction.
Although the aeroscreen has taken IndyCar driver safety to unparalleled heights, the device’s combined weight of nearly 60 pounds with the titanium halo from Pankl, the 9mm thick PPG laminate screen, plus its chassis mounting frame, has contributed to the Dallara DW12’s heft.
The use of the screen in front of the halo has also been an ongoing contributor to heat management issues in the cockpit due to the limited amount of onrushing air reaching the drivers, who also sit between the engine’s oil and water radiators which transfer an exceptional amount of heat into the cockpit.
With weight and driver cooling as the clearly defined areas to improve, the second-generation aeroscreen has undergone key developments to address both areas. Thanks to a new manufacturing process developed by Pankl that requires less material, the weight of the titanium halo has been reduced by nearly seven pounds — 6.8 to be exact. It’s a reduction that will benefit the field for years to come.
The new 6mm aeroscreen from PPG, which was originally meant to go live at the May 10-11 race on the IMS road course, will be used exclusively on road and street courses. IndyCar’s 2020-spec 9mm laminate, will stay in service for the Indianapolis 500 and all remaining ovals with no alterations.
The first-generation laminate offers immense strength and is perfectly suited to handle oncoming objects at speeds of 200mph or more on big ovals, but that thickness and its related weight has been more than what the project partners have deemed as necessary for the slower road and street circuits.
More here: https://racer.com/2024/04/17/lighter-co ... ong-beach/
#4
MonteCristo wrote: 1 month ago
CONFIRMED: POURCHAIRE TO DRIVE FOR ARROW MCLAREN AT LONG BEACH
Théo Pourchaire will race the No. 6 onsemi Arrow McLaren Chevrolet at the Acura Grand Prix of Long Beach on April 19-21 as David Malukas recovers from a left wrist injury and surgery.
Pourchaire, a 20-year-old from Grasse, France, is set for his NTT INDYCAR SERIES debut with Arrow McLaren following a successful racing season in Europe, where he clinched the 2023 FIA Formula 2 Championship. He secured two wins and 10 podiums as he led his French-based team, ART Grand Prix, to its first Formula 2 title. Pourchaire is the youngest driver to win races in both Formula 3 at age 16 (Austria in 2020) and then Formula 2 at 17 (Monaco in 2021).
Re when Malukas will return....
As Malukas’ recovery timeline extends beyond the originally anticipated six weeks, the team will continue to evaluate his health with his medical care team. Confirmation on the driver for the No. 6 NTT DATA Arrow McLaren Chevrolet for the Children’s of Alabama Indy Grand Prix powered by AmFirst on April 28 will come in due course.
https://www.indycar.com/news/2024/04/04 ... rowmclaren
#5
ALSO HARVEY, AND SIEGEL TO DRIVE FOR COYNE THIS WEEKEND AT LONG BEACH
Veteran Jack Harvey and rookie Nolan Siegel will drive for Dale Coyne Racing this weekend at the Acura Grand Prix of Long Beach.
Harvey, from England, will drive Coyne’s No. 18 Honda as an additional start to his partial schedule with the team this season. He qualified 27th and climbed to 18th in the season-opening Firestone Grand Prix of St. Petersburg presented by RP Funding on March 10 before ceding that seat to Siegel at The Thermal Club $1 Million Challenge on March 24.
INDY NXT by Firestone points leader Siegel, from Palo Alto, California, raced an NTT INDYCAR SERIES car for the first time at Thermal. Siegel, 19, just missed the feature race after finishing seventh in his heat, missing the final transfer spot by one position and less than six-tenths of a second.
Siegel replaces veteran sports car ace Colin Braun in DCR’s No. 51. Braun was contracted to race for the team at St. Petersburg and Thermal for his first two NTT INDYCAR SERIES starts. He finished 22nd after starting 25th in his first series start at St. Petersburg and didn’t advance from his heat at Thermal.
https://www.indycar.com/news/2024/04/04 ... -longbeach
#6
Post by John »
FRONT ROW FRO on pole!
2: Power
3: JoNew
4: Herta
5: Ericsson
6: Palou
CEREAL IS A SOUP.
Vassago
Favourite Motorsport: Formula 1, IndyCar
Favourite Driver: Senna, Clark, Montoya
Favourite Circuit: Circuit Gilles Villeneuve
#7
Post by Vassago »
FRO has gone backwards fast.
O'Ward run into the back of Rossi and tried to blame it on Blomqvist hitting him :whistling:
07.04.1968 - Flower of Scotland when will we see your like again?
01.05.1994 - We'll never forget...
Vassago
#8
Post by Vassago »
Vintage fuel saving win for who else but Dixon. Not exactly a classic otherwise. One crash for Rasmussen and Herta bumping Newgarden at the hairpin which decided 2nd place late on.
Post by DoubleFart »
Dixon drove a fantastic race.
MonteCristo wrote: 2 years agoVettel: Not a fan at all on track. But off track, good guy.
Car(s) Currently Owned: Citroën C2 1.4 (2006)
Vassago wrote: 3 weeks ago One crash for Rasmussen and Herta bumping Newgarden at the hairpin which decided 2nd place late on.
That was this talent that should go to F1. Doing a Stroll here.
#11
Post by John »
Only the US press thought Herta was F1 material, to be honest.....
Slow race, as usual here. MSR has got a qualifying bullet, let's see if they can figure out the race day setups.Interesting how Linus have sort of stalled out at the beginning of the season compared to his stunning displays at MSR last year.
CEREAL IS A SOUP.
What happened to Power? Didn't catch how Dixon got ahead in the highlights that I saw.
Real Name: Jacob
Favourite Racing Car: Panoz GTR1
Favourite Driver: Alex Zanardi
Favourite Circuit: Bathurst
#13
Post by Cheeveer »
MonteCristo wrote: 3 weeks ago What happened to Power? Didn't catch how Dixon got ahead in the highlights that I saw.
Dixon passed him easily on track as they were saving fuel.
