Join us here in ranking Ayrton Senna's Formula 1 cars! viewtopic.php?f=32&t=16038
GPL
Discuss everything from the latest motor racing sims, to the oldest arcade racing games, whatever takes your fancy!
Re: GPL
Post by PTRACER » 4 years ago
Any wheel that's good for sim racing. I'm glad I have my G25 with the shifter. I mainly race with keyboard atm though.
Racing is living and everything that happens in between is just waiting.
Post by Cheeveer » 4 years ago
G25's doesn't break... except for the shifter. I've had mine since it was released (2006?) and the wheel hasn't missed a beat. I guess those can be scored quite cheap nowadays.
My pedals and my shifter have glitches on and off for some time, I've had to take them apart to clean the pots. Everything is working fine now though.
I bought a Thrustmaster TH8RS shifter in January, also a solid piece of kit. Much better than the G25 shifter, but it also costs as such.
ReneLotus
Post by ReneLotus » 4 years ago
I'm using the Logitech Driving Force GT. It has a sequential shifter, but I'm enjoying it very much.
I am Stefan GP
I am Stefan GP
Post by Antonov » 4 years ago
I started the game, but when I try to run on, eg the streets of Monaco, and press green; the computer crashes to desktop.
Maybe I did something wrong with 3D accelaration or screen resolution? Would love to play... I used the update as indicated by Cheeveer.
Antonov wrote:I started the game, but when I try to run on, eg the streets of Monaco, and press green; the computer crashes to desktop.
If you've loaded the game straight from the disc and not updated it, it's never going to work...
Hmm, I suspect you need to patch it up further. Try and install this very useful utility: http://gem.ebi-service.de/downloads.html
That will add a lot more options to make the game run smoother. It will also allow you to install mods.
CTD's are usually because of graphical glitches - it wasn't originally made for 2015 graphics cards. But with the above utility it can make it work - I use the "Open GL V2" rasteriser and 1920x1080 resolution. It runs very stable with that.
There's also this guide: http://gplworld.org/easy-installation-guide.html
The Sim Racing Mirror Zone is THE GPL forum: http://srmz.net/index.php?act=idx
ReneLotus
Cheeveer wrote:There's also this guide: http://gplworld.org/easy-installation-guide.html
I use the all in one installer from the forum and GEM+.
After installing GPL you need to create a player profile and then close GPL again. Then open GEM and add your installation to GEM and it will work everytime.
Post by PTRACER » 3 years ago
Just in case you thought GPL needed a touch more realism...look at the driver's head!
https://vimeo.com/143319235
I'm blown away by what modders are doing to this game.
Post by erwin greven » 3 years ago
yeah, i think i should try to get GPL running again.
It's really, really good. I only drive it with keyboard, but if you tune the AI right, they're so much better to race with than say rFactor's AI.
There's also a patch out that removes the black bars from the field of view, so it's now proper full screen.
Post by Cheeveer » 3 years ago
Thanks for mentioning that, PT! Peaking my interest for GPL again. I'm hearing that F1 1955 and CanAm 1966 mods are imminent! (imminent in GPL lingo is usually at least 6 months, but still)
Post by Ian-S » 3 years ago
The driver head is, in theory, really easy to do (especially in nr2003), what interests me is how they got the suspension to move in GPL but you can't do the same thing in NR (the reason I'm comparing to NR is because the two games share much of the same code).
Is there any car building tutorials for GPL available that show the construction code and switches like there is for NR?
I've tried looking but never really found anything.
Artificial Intelligence is no match for Natural Stupidity.
Ian-S wrote:The driver head is, in theory, really easy to do (especially in nr2003), what interests me is how they got the suspension to move in GPL but you can't do the same thing in NR (the reason I'm comparing to NR is because the two games share much of the same code).
You should ask that at SRMZ. If they can't answer that, then probably no.
