Depends if you decide to delete your entire history in a couple of days...
The late addition of the controversial halo into Formula 1 this year has forced teams to heavily modify their chassis to accommodate the device.
Fitted to a number of cars during practice sessions last year, the halo has become compulsory for the 2018 season as a standardised component for all teams.
“Adopting it has been a significant challenge,” said Mercedes technical director James Allison.
“This is not a light piece of work, it’s several kilograms of titanium that need to be put on the car, and all the changes that we needed to do to accommodate it so that the overall car would still stay below the weight limit.
“We had to strengthen the design of the chassis so that it would be take roughly the weight of a London double-decker bus sitting on top of this halo to make sure it would be strong enough to withstand the type of event they are designed to protect the driver’s head against.”
However the sheer weight and chassis implications of the device have not been the only concerns, with the airflow interruption having an impact on engine cooling and the aerodynamic efficiency of the rear wing.
“This unadorned round tube is quite bad aerodynamically,” Allison explained.
“We’re all permitted to modify the halo in a way that will be individual for each team, because we’re permitted to fit an aerodynamic faring around it, which gives us a certain amount of scope to mitigate the affect that it has on the aerodynamics of the car.
“And what we’re aiming to do there is ensure that the wake of this halo does not effect the smooth running and powerful performance of the engine, so we make sure the wake of the halo does not get ingested by the engine, and we also make sure that its designed such that it doesn’t damage the behavior of the rear wing.”
Assuming there was a problem, Seb doing one lap doesn't exactly seem very scientific
Mel (Kenyon) and Don decided to add a roll cage on the Eagle, (above) but because the cage tumbled the air over the car and made it unstable it was removed and replaced with the conventional roll hoop (below).
Bad links? I dont understand. The images show for me and also if I open the pic links in a new tab also show.
